[GAMBIT] Negative Volume!!
Old   November 6, 2015, 03:41
Default Negative Volume!!
Aja
aja1345 is on a distinguished road
It is created the negative volume in the following geometry. Why?
Please see volume 67.
http://www.4shared.com/zip/hS41qJnCc...ells-SRF5.html
I am grateful that guide me about this case.
Thanks.
Best.
Aja
aja1345 is offline   Reply With Quote
Old   November 6, 2015, 07:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
go in examine mesh and select "volume" as Type.
Then Gambit will automatically set the lower and upper values in both slider.
You are right you have some negative volume cells.
Set now the upper value to 0 and press enter.
Gambit will show you where they are.
My advice: add more nodes an edge 592 especially in the middle
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
[ICEM] negative sector volume adam2008 ANSYS Meshing & Geometry 0 August 9, 2014 00:24
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
remeshing due to negative volume error Doginal CFX 1 August 21, 2011 21:50
