[ANSYS Meshing] Problem with meshing a 3D perpendicular disk in flow
Old   September 26, 2015, 09:22
Default Problem with meshing a 3D perpendicular disk in flow
mojtaba ghafoori
wmg1368 is on a distinguished road
i want to mesh one fourth of flow around a 3D disk which subjected perpendicular (for Cavitation). but i don't know how to block in DM.
when i use slice option the wall of disk divide to many faces and ansys produce contact region also in fluent wall B.C divide to many wall condition.
can anyone help me to do that in ansys meshing or icem?
wmg1368 is offline   Reply With Quote
Old   September 28, 2015, 00:37
Antanas is on a distinguished road
Don't use slice, use multizone meshing method
Antanas is offline   Reply With Quote
Old   October 6, 2015, 17:18
mojtaba ghafoori
hi thank you for reply
i made it with icem fluent complain about high aspect ratio(max 1000-2000). i want yplus to be around 30 near the disk. is there any way to decrease A.R but still have low yplus?
Old   October 8, 2015, 11:01
Default ANSYS 3D meshing for water turbine with k-omega model
TKP
TKP
TKP is on a distinguished road
My work in ansys fluent is transient flow simulation for a flow over water turbine with k-omega SST model. I have applied curvature and body sizing for the domain during meshing in ANSYS. Along with that I have given inflation in the turbine blades so that it can capture the flow near blades. But when I do so my MAXIMUM ASPECT RATIO becomes 5608, average Aspect ratio 4.0. But solution is converging. I want to know whether this high maximum ASPECT RATIO is acceptable or NOT?
Thank you in advance.
TKP is offline   Reply With Quote
Old   October 12, 2015, 08:03
mojtaba ghafoori
hi
i think it depends on what solver you are using.
but when high AR cells are far from high gradients region i think your mesh will work.
there is topic that you can find your answer
i think they said in 3D cases with AR up to 8000 fluent will work. but i am not sure it is better you find that topic and check it.
[ICEM] Meshing according to the flow problem - External Aerodynamics. shereez234 ANSYS Meshing & Geometry 2 August 17, 2023 15:57
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
3D Pipe Flow Problem: Velocity profile is not symmetric malicemethods FLUENT 0 May 27, 2015 11:51
[ICEM] Meshing Problem ? Leifheit ANSYS Meshing & Geometry 3 December 4, 2014 18:09
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
