October 5, 2015, 05:12 |
Inflation vs. pinch control
Edee O'Hare
Rep Power: 12 |
I have rather simple 2D geometry of the flat plate in the wind tunnel. I would like to apply inflation layer around that plate, however the building of the layer fails giving a warning message: At least one pinch control has a tolerance below one or several scoped size control. Reduce tolerance or remove any pinch control(s) in close proximity of any such scoped size control(s), otherwise surface meshing might fail. I am not using any manual pinch control and if I reduce pinch control tollerance in the mesh defeaturing section it has no result. Thank you for any suggestions Edee |
October 14, 2015, 10:22 |
Sarang Dalne
Can you share the model. Meshdat or mechdat would work.
[ANSYS Meshing] Airfoil Meshing Pinch Control Tolerance | diegojolin | ANSYS Meshing & Geometry | 6 | January 16, 2019 18:12 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
Fluent diverges when using inflation layers | ziggo | FLUENT | 4 | August 9, 2013 12:11 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation | peterputer | ANSYS Meshing & Geometry | 0 | May 15, 2012 08:53 |
