October 16, 2015, 17:03 |
Boundary layer on corners
vahab solgi
Rep Power: 10 |
Hello every body
I want to generate BL on the walls of a cylinder which has a shape like the attachment in Gambit, but the following error occurs on meshing the volume: "Currently 3D boundary layers are limited to flat face groups with the same boundary layer on all faces. a discontinuity has been found where one face has a boundary layer and the adjacent one does not. the problem occur in volume along following edges (shown in image by "here")" In the attachment I have shown what I want the BL be after meshing the volume. What should I do to tackle this error? Thanks in advance every body. |
October 19, 2015, 01:17 |
Maxime Perelli
Rep Power: 41 |
can you provide your dbs file?
In memory of my friend Hervé: CFD engineer & freerider |
October 21, 2015, 17:46 |
Dear Max
vahab solgi
Rep Power: 10 |
thanks for the reply
Unfortunately I can not send the file but I found the answer my self. The error is because that the boundary layer's borders have to collide each other or reach to a solid face and I did not consider this issue. The problem solved... Thx |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 04:26 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
No-slip condition for non-resolved boundary layer in open channel banks | Lupocci | Main CFD Forum | 1 | January 17, 2013 03:11 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[snappyHexMesh] Boundary layer addition at corners with sHM | bouclette | OpenFOAM Meshing & Mesh Conversion | 6 | July 27, 2011 08:32 |
