[ICEM] Splitting Blocks
Old   November 9, 2015, 09:21
Default Splitting Blocks
Florian
Rompastompa is on a distinguished road
Hey guys,
i have some problems with splitting blocks.
The picture below shows the blocking till now. The red an the green lines are parallel to each other. I am triing to insert a blocking which looks like the blue lines. So how can i Block this without starting from the beginning.
Thanks for any help
Rompastompa is offline   Reply With Quote
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[ICEM] Splitting blocks without affecting node distribution Crank-Shaft ANSYS Meshing & Geometry 1 June 20, 2014 09:36
[ICEM] Automatic linear interpolation of parameters when splitting blocks Ivan ANSYS Meshing & Geometry 0 August 14, 2012 07:30
