[ICEM] Meshing a cylinder with ICEM
Old   November 18, 2015, 06:47
Exclamation Meshing a cylinder with ICEM
Pablo Díaz
Palo_DIaz is on a distinguished road
Hi everyone:
I´m trying to mesh a cylinder in ICEM by following this steps:
1.-Create and associate 2D blocking to a revolution section of the cylinder
2.-Create 3D blocks by 180 degree rotating :
-blocking, create block, 2D to 3D, rotate and unmark collapse axis nodes (to obtain structured blocks near the axis)
And i get a) (attached image)
That i want to do now is to modify the blocks near to the axis to look like the image b) instead of a). Could you help me?
Very thanks for your help, I am a beginner in ICEM meshing
Palo_DIaz is offline   Reply With Quote
Old   November 25, 2015, 09:52
Maxim
-Maxim- is on a distinguished road
I don't have experience with 2D to 3D blocking but I would just do it in 3D. Create an O-Grid and adjust the edges after the split according to your wishes.
If you don't know how an O-Grid is set up, please have a look at the tutorials. O-Grids are being used in some of them.
I also had a question about cylinders here. Maybe that helps.
-Maxim- is offline   Reply With Quote
axis nodes, axisymmetric, icem, mesh
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[ANSYS Meshing] Hybrid meshing ICEM djoul ANSYS Meshing & Geometry 2 January 17, 2012 18:18
meshing on cylinder fails ICEM potac ANSYS Meshing & Geometry 0 October 25, 2011 05:21
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 4 October 19, 2010 16:45
