[ICEM] Screen rotation problem in v15
Old   April 19, 2014, 06:09
Default Screen rotation problem in v15
siw
Stuart
siw will become famous soon enough
In ICEM CFD v15 when I put the cursor on some piece of geometry in the GUI and hold down the left mouse button to rotate the geometry about where the cursor is ICEM is not rotating about that point. Instead it is rotating about some (seemingly) arbitrary different point and so making it much harder to get the views I want which makes blocking difficult.
This was not a problem in v14.5. Where I could put the cursor of any geometry and holding down the left mouse button would rotate about that local point where the cursor was projected onto the geometry on the GUI.
This is a step backwards by ANSYS; either a bug or a removed feature, because it was never a setting I had to make from the defaults. Does anyone else have this?
Regards.
siw is offline   Reply With Quote
Old   November 12, 2014, 00:10
Bappaditya
bappa is on a distinguished road
I think this reply comes a bit late and you have already figured out how to fix this issue. Anyway here is how to rotate about a local point in Ansys ICEM V15. Simply double click at the point location (about which you want to rotate about) and used left mouse button to keep rotating.
Hope this helps.
bappa is offline   Reply With Quote
Old   December 11, 2015, 09:00
Default Rotate point on ICEM CFD v15
Paul Silva
luap is on a distinguished road
Send a message via Skype™ to luap
I cant rotate point locally on ICEM v15 also.
SIW, what have you done to solve it?
Regards.
luap is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[OpenFOAM] paraview split screen problem ziemowitzima ParaView 1 March 16, 2011 14:07
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem Setup: Bi-Axial Rotation Possible? Harmeet CFX 6 February 11, 2005 15:27
