[DesignModeler] Twisted tape in circular tube |
January 4, 2016, 22:57 |
Amrut Ghodake
Rep Power: 10 |
Hello All,
I need to simulate a Copper tube with aluminum twisted tape inside it. Water will be flowing through the tube. Can anyone please confirm that how the geometry should be? The region between twisted tape and tube should be hollow or some material should be there? I have tried to draw the twisted tape using sweep command and then extruded the thin cylinder on it. Is it the right way to do so? Also, this tube is going to be used in the solar water heater and whole assembly will be tilted with 32.5 deg with horizontal. Next question is, how to take care of these conditions in Fluent.?? Please help me, i urge you all as i am new to this Fluent world. |
January 6, 2016, 23:56 |
#2 | |
Amrut Ghodake
Rep Power: 10 |
August 13, 2020, 14:24 |
Ravi Agrawal
Hi Amrut, I know its very late, but just curious if you have solved this problem. I am working on similar one. I am having issue in assigning boundary condition to the wall. Is is heat flux on outer wall.
flow in a tube with twisted tape inserts | kamyar | Main CFD Forum | 2 | September 15, 2021 01:53 |
[ANSYS Meshing] Twisted Tape in pie | stalon67 | ANSYS Meshing & Geometry | 10 | March 26, 2017 21:34 |
circular tube with twisted tape insert | ABDOLBAQI | FLUENT | 1 | January 4, 2016 07:47 |
CFD simulation of tube with twisted tape | amrutghodake | FLUENT | 0 | January 4, 2016 07:41 |
emptying liquid from spinning circular tube | uvce | Main CFD Forum | 0 | July 2, 1999 10:26 |
