[DesignModeler] Creating two bodies but only meshing 1 |
January 8, 2016, 06:47 |
Rep Power: 10 |
Hi all,
I would like to create a domain with a subdomain that I can later add momentum sources to. But I don't want this subdomain to be meshed separately. It's inside the larger domain and I would like that to be meshed as if the the subdomain did not exist. I created the bodies using Slice Material and then creating a part from those two bodies, but then when I mesh it Ansys tries to conform to the subdomain instead of ignoring it. EDIT: I may have found a solution, but I don't know how elegant it is. I do another extrude of the subdomain, but unite this to the whole domain with a boolean operation. Now I have 2 bodies, one is the subdomain and one the whole domain, and when meshing the subdomain is ignored. Don't know if it will work for solving though EDIT2: Previous solution doesnt' really work, the domains are regarded as independent. |
[DesignModeler] Creating Two Separate Bodies in Design Modeller | ashtonJ | ANSYS Meshing & Geometry | 39 | June 6, 2018 17:31 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[DesignModeler] Can I keep some bodies freezed before meshing? | yahya | ANSYS Meshing & Geometry | 4 | December 3, 2012 11:32 |
doubt on meshing | joe | FLUENT | 2 | September 12, 2005 13:17 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
