February 2, 2016, 18:23 |
How to write a such script?
Sor-Trondelag
Rep Power: 10 |
Hello everyone,
I'm facing a headache problem right now. Say I'm having 10,000 bodies imported from .stp file, each of them has different name, end with plate thickness at the last two characters, like 'body1_PL12', 'body2_PL14'. The question is how can I use script to parse the body name and assign it to the body thickness properties? Many thanks if anyone can shed light here. Regards Huisky |
February 3, 2016, 00:24 |
Rep Power: 14 |
never done something like that but I guess ...use excel for that.
call body by given name and assign thickness for that body name! |
February 3, 2016, 03:40 |
Sor-Trondelag
Rep Power: 10 |
February 3, 2016, 16:24 |
Rep Power: 14 |
First place I will look is "help section" in Ansys!
they have explained it with small example, try that and see if it will help you in some way Also look into scripting guide in help section as to how you can bring excel and Ansys together. If you dont understand anything please ask! |
February 4, 2016, 05:03 |
#5 | |
Sor-Trondelag
Rep Power: 10 |
Ok, I will do that. But I still wonder will that make the operation quicker?
To start with, i found a .js script located under ansys installation path. Will it be straightforward to modify this script a little bit and achive my goal? /************************************************** ***************** Function to set Material, 2D behavior, and thickness for Bodies from Excel The Excel file contains data as 4 columns: NS_Name Mat_Name Behavior Thickness Line-1 is header Line-2 to "n" contains valid data Behavior options are: Axisymmetric, Plane Stress and Plane Strain Thickness input is valid only for Plain Stress Assumptions: 1. Model is 2D 2. The materials are already defined in Engineering Data 3. There are no empty cells between two rows of data in Excel 4. The Excel file contains valid NamedSelections of the surface bodies The script is developed/tested for Mechanical in WB 13.0 ************************************************** ********************/ // Ask the user to choose the excel file var dlg = DS.Script.AnsObjectFactory.CreateDispatchObject(DS .Script.GenWBProgId("WBControls.WBFileDialog")); dlg.DefaultFile = "InputData.xlsx"; dlg.DefaultDirectory = "./"; dlg.Filter = "Excel files (*.xls; *.xlsx)|*.xls;*.xlsx"; dlg.FilterIndex = 0; dlg.ForOpen = true; dlg.Popup(0); // Popup the file browser var ExcelFilename = dlg.SelectedFile; var oScript = DS.Script; var BodyGName = new Array(); var BodyMat = new Array(); var BodyType = new Array(); var BodyThick = new Array(); // Valid if BodyType == Plane Stress // Read the Excel file and store all data in Arrays if (ExcelFilename != "") { var Excel = new ActiveXObject("Excel.Application"); Excel.Workbooks.Open(ExcelFilename); var sheet = Excel.ActiveWorkbook.ActiveSheet; var i=2; // We will start on line 2 in the excel spreadsheet // Read all the required data from Excel while (String(sheet.Cells(i,1))!= "undefined") {// Scan first column until empty cell BodyGName[i-2] = String(sheet.Cells(i,1)); BodyMat[i-2] = String(sheet.Cells(i,2)); BodyType[i-2] = String(sheet.Cells(i,3)); if (BodyType[i-2] == "Plane Stress") BodyThick[i-2] = Number(sheet.Cells(i,4)); i++; } Excel.Application.Quit(); // Kill Excel Application Excel= null; } // If Excel contained any valid data Proceed.... if (BodyGName.length > 0) { var branch = DS.Tree.FirstActiveBranch; var matList = branch.Project.MaterialNames; // Access all available materials var GeomGrp = branch.Model.PrototypeGroup; // Access all bodies var componentGroup = oScript.GetNode(branch.ComponentGroup.ID); // Access the NamedSelections var cCount = branch.ComponentGroup.Components.Count; var component; var body = null; oScript.changeActiveObject(GeomGrp.ID); // Set 2D Behavior ListView.ActivateItem("2D Behavior"); ListView.ItemValue = "By Body"; // Now loop over the NS read from Excel and apply properties for (var i=0; i< BodyGName.length; i++) { var bodyG = BodyGName[i]; // Loop over the defined NS and check the name for( var j = 1; j <= cCount; j++ ) { var compI = branch.ComponentGroup.Components.Item(j); SM.Clear(); if (compI.Name.toLowerCase() == bodyG.toLowerCase()) { // Select the Specific NS in the Tree oScript.changeActiveObject(compI.ID); // Add the component to Selection Set oScript.doTreeActivateSelection(); // Apply properties to each body in the selection set assignProps_onSelectedBodies(i); } } } WBScript.Out("All inputs are now set...", true,"Message"); } else WBScript.Out("Unable to use the inputs from Excel file..." + "\n" + "Please check the Excel file", true,"Error"); function assignProps_onSelectedBodies(index) { var iNumSelected = SM.SelectedCount; var aPartIds = new Array(); var aTopoIds = new Array(); // Access each bodies and store their PartIds and TopoIds for( var k = 1; k <= iNumSelected; k++ ) { aPartIds.push(SM.SelectedPartID(k)); aTopoIds.push(SM.SelectedEntityTopoID(k)); } // Loop over the stored list, select one body at a time and apply proprties for ( var l = 0; l < iNumSelected; l++ ) { SM.Clear(); SM.AddToSelection(aPartIds[l], aTopoIds[l], false ); // Go the selected Body in Tree oScript.doGoToCorrespondingParts(); //var item = oScript.tv.FirstSelectedItem; oScript.tv.SelectedItem.Tag.MaterialName = BodyMat[index]; // Apply Material // Apply Behavior ListView.ActivateItem("Behavior"); ListView.ItemValue = "" + BodyType[index]; // Apply Thickness if (BodyType[index] == "Plane Stress") { ListView.ActivateItem("Thickness"); ListView.ItemValue = "" + BodyThick[index]; } } DS.Script.fillTree(); } Quote:
February 4, 2016, 17:04 |
#6 | ||
Rep Power: 14 |
HELL YEA! Quote:
Use "Debugger" in this script and see what each line is doing. u r on the right path! Cheers KAPI |
February 8, 2016, 14:19 |
#7 | |
Sor-Trondelag
Rep Power: 10 |
Thanks for your comments. However, things are not so easy, especially when the API documents are rare for DM scripting.
February 8, 2016, 16:20 |
Rep Power: 14 |
can you take a pic of DM on how you are doing it and what functions you are using in DM? I can have a look and give you suggestions!
I know its very frustrating cuz of hardly any documentation but thats how it is! On the other hand thats why its makes scripting more fun (not when you are in hurry for answers) Happy scripting! Cheers KAPI |
February 8, 2016, 16:30 |
#9 | |
Sor-Trondelag
Rep Power: 10 |
yes, thanks in advance.
Here is the illustration of my procedure. Quote:
February 9, 2016, 16:39 |
#10 |
Rep Power: 14 |
Alrighty, so what are things we need to do to arrive to your answer!
Steps: 1. Create geometry 2. Select Body in the list below one by one 3. Connect excel with WB 4. Transfer Names of body to excel 5. Extract thickness from name, make another column for thickness 6. Revert back to same body name 7. Rename the body or keep the same name 8. Pick thickness with body name from excel 9. Close Excel So we gotta work on these steps one by one. - First up, are your using scripting to import your geometry? - Do you need to apply any other functions on this geometry? - Which format are you importing geometry in? - How are you naming each body? - Any changes you need to do after import? Hope this will give u path thru to work on! I normally connect my mesh with excel and work thru but excel with DM is similar! KAPI |
February 10, 2016, 03:08 |
#11 | |
Sor-Trondelag
Rep Power: 10 |
Thanks very much for your reply. Here are my comments:
1. I'm importing my geometry manually by click 'import' from DM; 2. Nope. Assign thickness is the only action that i want to do within DM; 3. The geometry was imported from .stp file; 4. The body names are shown as the picture. Only the last 3-4 characters are meaningful, T, stiffener, F, flat bar, PL, plate; 5. After importing, normally I will do a 'analysis' to the geometry quality via DM, but this is not required. What I need is only for assigning thickness to each body. Thanks in advance. Quote:
February 10, 2016, 19:09 |
#12 |
Rep Power: 14 |
you can use the code you posted before to start.
Just change excel file name, body name and other things! this way you know where you are having error and eradicate it and keep moving! Sorry just dont have enough time to write code for you, pretty busy with work these day! |
[ICEM] Script: problems with face names | Maweil | ANSYS Meshing & Geometry | 3 | April 16, 2019 09:10 |
Have only process 0 write data | syavash | OpenFOAM Running, Solving & CFD | 1 | November 3, 2015 06:05 |
CFX mesh script error | Malik77 | CFX | 0 | June 24, 2011 07:42 |
Perl script for intialisation | pratik mehta | CFX | 2 | September 10, 2008 03:09 |
pmovlink script | Arnab | Siemens | 4 | August 1, 2004 22:50 |
