[ANSYS Meshing] Scale geometry but mesh size to remain same |
June 18, 2012, 06:57 |
Sangram
Rep Power: 15 |
Dear Members,
I have a simple 2D axis-symmetric analysis of a supersonic nozzle system that I have done in Ansys Fluent 13.0. I want to do the analysis for same geometry with dimensions scaled (1.5x, 2x, etc). But it seems that after I scale the geometry (in Fluent) the mesh is also scaled. Now this causes the mesh to be scaled and the elements become distorted and the solution no longer converges. Here is my question:- 1. Is there any way to scale the geometry , while the mesh element size remains the same. The mesh was generated in program outside ANSYS, so I need to be able to do this in FLUENT itself. In case this is not possible, 2. Is there a way to import the mesh in Ansys meshing (or ICEM CFD) and trace the mesh so that after the scaling the mesh can be made to remain the same. Any help, is highly appreciated. Sangram P. |
February 12, 2016, 05:19 |
consequences of scaling geometry
Oula
Rep Power: 11 |
Dear Sangram,
I know my post will not answer your question, but I would be grateful if you can answer mine. I am simply dealing with relatively big geometry dimensions are (1.96m * 6.76m * 2.5m ). When I start my simulation, I used scaled geometry as I thought it is good idea and will save time, then I found I missed important thing that I need to scale the boundary conditions. My question is what other parameter I need to scaled as well. Do I need to scale the default parameters in fluent? In your opinion, does the scaling can give me misleading results. Thank you in advance for your help. Oula |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
unstructure mesh size control near to wall using gambit | lalit kumar | FLUENT | 4 | July 6, 2010 15:13 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Gambit: mesh size to small??? | Ralf Schmidt | FLUENT | 1 | January 28, 2006 01:26 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
