[ICEM] ICEM-CFD: unsatisfying geometry display after import
Like Tree1Likes
  • 1 Post By julian_007
Old   August 20, 2021, 07:54
Default ICEM-CFD: unsatisfying geometry display after import
julian_007 is on a distinguished road
Dear Community,
for my master-thesis I'm working with the CAD program Creo Parametric and the plug in for Ansys Workbench, due to do an parametric study in CFX.
The geometry I generated in Creo, with a very high quality display of the edges, appears after importing into ICEM not as smooth as I want it to.
See attached picture:
https://www.cfd-online.com/Forums/me...m-geometry.png
By lowering the the triangulation tolerance, like it is solution it is shown, question 5: http://www.cfdyna.com/CFDHT/ICEM_FAQ.html
doesn't help me either...
When I try to associate the lines to the curves in ICEM, I need to click more than once to get the curve, which implies there are more than one curve lying on top of each other, this in my opinion causes a failed mesh import into CFX-Pre.
Can someone give me a hint to avoid this problem?
Thanks a lot for your help!
julian_007 is offline   Reply With Quote
Old   August 20, 2021, 08:13
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Originally Posted by julian_007 View Post
Dear Community,
Couple of hints.
  • If the geometry is simple enough, build it in ICEM CFD.
  • If importing from Creo try IGES and STEP file imports ( not sure what you are using at the moment).
  • Try building topology with tolerance = 1/10th of the smallest curve (try other values too as this is just a rule of thumb.
  • If the geometry is still problematic, try manually rebuilding the curves and then surfaces which are causing issues.
shereez234 is offline   Reply With Quote
Old   August 20, 2021, 08:23
Originally Posted by shereez234 View Post
Couple of hints.
Thanks for the hints!
Solved the geometry display with: surface --> show full
shereez234 likes this.
Old   August 20, 2021, 08:30
shereez234's Avatar
M Sereez
my bad. I had the idea that your problem was multiple edges and all.
creo parametrics, icem geometry, triangulation
Problem Importing Geometry For Mesh in ICEM CFD losiola ANSYS 1 May 5, 2020 16:10
Icem cfd import problem burhanuddinkapadia110 ANSYS 0 April 24, 2018 03:52
[ANSYS Meshing] Import ICEM CFD .tin into Ansys Workbench ahammack ANSYS Meshing & Geometry 1 March 3, 2016 02:37
[ICEM] Import ICEM Mesh & Geometry to ADINA support file ArmanZohrabi ANSYS Meshing & Geometry 0 September 7, 2015 11:06
[ICEM] Import a Nastran file into ICEM CFD norger ANSYS Meshing & Geometry 0 May 14, 2012 07:37
