[ICEM] ICEM-CFD: unsatisfying geometry display after import |
August 20, 2021, 07:54 |
Rep Power: 4 |
Dear Community,
for my master-thesis I'm working with the CAD program Creo Parametric and the plug in for Ansys Workbench, due to do an parametric study in CFX. The geometry I generated in Creo, with a very high quality display of the edges, appears after importing into ICEM not as smooth as I want it to. See attached picture: https://www.cfd-online.com/Forums/me...m-geometry.png By lowering the the triangulation tolerance, like it is solution it is shown, question 5: http://www.cfdyna.com/CFDHT/ICEM_FAQ.html doesn't help me either... When I try to associate the lines to the curves in ICEM, I need to click more than once to get the curve, which implies there are more than one curve lying on top of each other, this in my opinion causes a failed mesh import into CFX-Pre. Can someone give me a hint to avoid this problem? Thanks a lot for your help! |
August 20, 2021, 08:13 |
#2 | |
August 20, 2021, 08:23 |
#3 | |
Rep Power: 4 |
Solved the geometry display with: surface --> show full |
August 20, 2021, 08:30 |
creo parametrics, icem geometry, triangulation |
Problem Importing Geometry For Mesh in ICEM CFD | losiola | ANSYS | 1 | May 5, 2020 16:10 |
Icem cfd import problem | burhanuddinkapadia110 | ANSYS | 0 | April 24, 2018 03:52 |
[ANSYS Meshing] Import ICEM CFD .tin into Ansys Workbench | ahammack | ANSYS Meshing & Geometry | 1 | March 3, 2016 02:37 |
[ICEM] Import ICEM Mesh & Geometry to ADINA support file | ArmanZohrabi | ANSYS Meshing & Geometry | 0 | September 7, 2015 11:06 |
[ICEM] Import a Nastran file into ICEM CFD | norger | ANSYS Meshing & Geometry | 0 | May 14, 2012 07:37 |
