April 18, 2016, 10:25 |
problem with mesh quality
yaseen
Rep Power: 10 |
hello everyone
I simulate free surface flow my geometry complex, so I divided into eight parts. sweap method used in ANSYS meshing for swepable bodies and tetrahedron and multizone method for others, but the problem is skewness which is 0.966 (max), I tried by sizing but I can not reduced it. Who can suggest me to improve my mesh quality. thanks |
April 18, 2016, 18:44 |
sizing is the best way to reduce your skewness and improve quality.
Please post your mesh where you are getting high skewness. You can use behavior "HARD" in sizing |
April 19, 2016, 07:16 |
yaseen
Rep Power: 10 |
thanks for your reply
my geometry is complex, some parts finer than others, what due you mean by(HARD) in sizing? the follow is my meshing model, thanks for your suggestion, max. value of skewness in the tetrahedron part http://www.cfd-online.com/Forums/att...1&d=1461063279 http://www.cfd-online.com/Forums/att...1&d=1461063297 http://www.cfd-online.com/Forums/att...1&d=1461063316 https://drive.google.com/open?id=0B3...GtsazRUbUVMYkk |
April 28, 2016, 08:22 |
Paritosh Vasava
Rep Power: 22 |
When you use sizing in Ansys Meshing, the 'behavior' can be 'Hard' or 'Soft'. By selecting soft, you are allowing Ansys meshing to over-ride the sizing, because it thinks that it can give you better mesh by NOT obeying the sizing you input.
Do post pictures of the mesh and model. |
April 28, 2016, 15:23 |
yaseen
Rep Power: 10 |
thanks for your reply, the following images are my model mesh
http://www.cfd-online.com/Forums/att...1&d=1461871206 http://www.cfd-online.com/Forums/att...1&d=1461871217 http://www.cfd-online.com/Forums/att...1&d=1461871230 http://www.cfd-online.com/Forums/att...1&d=1461871247 http://www.cfd-online.com/Forums/att...1&d=1461871260 http://www.cfd-online.com/Forums/att...1&d=1461871206 http://www.cfd-online.com/Forums/att...1&d=1461871217 http://www.cfd-online.com/Forums/att...1&d=1461871230 http://www.cfd-online.com/Forums/att...1&d=1461871247 http://www.cfd-online.com/Forums/att...1&d=1461871260 |
April 29, 2016, 02:16 |
use lower size elements where you need fine mesh and make sure you use behavior "Hard"
I strongly suggest to refer to Help section, read it thru if you dont get your answer then search for similar threads on this forum and even after this if you dont get your answer then only post a question!! I am sure you will get help from help section. |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Prism Quality mesh problem | bharath | ANSYS Meshing & Geometry | 5 | April 14, 2014 09:22 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
