[ANSYS Meshing] Pb with the import geometry
Old   June 8, 2016, 09:08
Default Pb with the import geometry
Francesco
Francesco1 is on a distinguished road
new_NACA-2412.txtHi every body,
i'm working on the NACA 2412 airfoil and after getting my coordinates with Javafoil, i export them into a .txt document. However, when i try to import to Ansys, the error of reading coordinates file appears. So i pissed me off
it attach the following document to show you the template that i use to.
If every could help me it would be great.
Thks to every one
Francesco1 is offline   Reply With Quote
Old   June 9, 2016, 20:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Follow the format for the Design modeller
https://www.youtube.com/watch?v=3VuZiDIl704
Far is offline   Reply With Quote
Old   June 10, 2016, 04:07
Francesco
Thks a lot. Now it works very well. However, i succeed it in importing the points and then in the 3D curve function I define it from point selection.
have a good day
[DesignModeler] Unable to Import Geometry Alan212 ANSYS Meshing & Geometry 3 March 17, 2015 11:26
[TurboGrid] import geometry summerverycool ANSYS Meshing & Geometry 5 July 8, 2013 07:39
how to import geometry file to turbogrid summerverycool ANSYS Meshing & Geometry 0 July 2, 2013 04:44
[DesignModeler] Import external geometry problem Houman ANSYS Meshing & Geometry 0 May 16, 2012 04:24
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
