June 13, 2016, 01:01 |
flowpath in blade modeler
zeinab
Rep Power: 10 |
hey everyone
I have a blade that I exported to blade design modeler and I draw 4 sketches for hub shroud and inlet and outlet.when,trying to make a flow path i can not change the number of layers from 0 to an other number,what should I do? my ansys is 17 and i draw sketches in xy plane. |
June 13, 2016, 20:13 |
June 14, 2016, 07:22 |
flow path
zeinab
Rep Power: 10 |
dear far
I can not access you tube,it is filtered in my country and no vpn works on that,could you explain what is my problem? my most important problem is that I can not change the number of layers so my flow path doesn't work.what should I do? |
June 17, 2016, 09:34 |
right click on layer 1
Véronique Penin
Rep Power: 12 |
Did you try to righ click on layer in your FlowPath window?
I think you hava "ad a layer above" or something like that. Take care, Véronique |
[BladeModeler] How to understand the modeling concept in blade modeler | devesh | ANSYS Meshing & Geometry | 34 | January 14, 2022 08:09 |
[TurboGrid] Slotted rotor Blade using Turbogrid | drcsm | ANSYS Meshing & Geometry | 0 | March 15, 2016 00:26 |
Blade modeler, Bladegen and Blade editor | drcsm | CFX | 0 | April 4, 2015 00:06 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 04:09 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 22:43 |
