June 15, 2016, 08:29 |
2D "parallel" meshing
Tim Kayser
Rep Power: 10 |
I am working with ANSYS R14.5 and willing to perform a 2D dual element slot geometry optimisation for an airfoil. So in general that does not sound too complicated, but for some reason the time spending for meshing is ridicously long. So for instance 6,09e+5 nodes and 5,4429e+5 elements it takes like almost two hours or so. Don't you think this is unreasonable long? My hardware details are: - Dell Precision T7810XL - Intel(R) Xeon(R) CPU E5-2640 v4 @2,4GHz - RAM 8GB - Windoes 7 Professional 64bit I have already looked for parallel meshing, but the setting at the moment already says 0CPU - so that it automatically takes as many as accesible - and even when I increase the number manually, it always runs with only 1 CPU during meshing. How can I decrease the meshing time in order to lower the mesh size for a more accurate result? Interested in any thoughts you've got. Cheers Tim |
June 16, 2016, 09:02 |
Tim Kayser
Rep Power: 10 |
well if possible, I'd rather like to stick to the "ansys mesher". I mean at least as long as there is any opportunity to reduce that time.
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
