[ICEM] blocks with different mesh types
Like Tree15Likes
Old   July 21, 2016, 00:45
Mahdi
metmet is on a distinguished road
Originally Posted by Daniel_Khazaei View Post
1) At first I have created the domain ...
it's done!
God bless you man.
After I created a thread related to this topic, I found your tutorial. Thanks dude.
Just a simple question, in which step you converted the structured mesh to unstructured mesh?
I'll be waiting for Sijal's new episode of Hybrid mesh tutorial.
Thanks both of you guys.
metmet is offline   Reply With Quote
Old   July 21, 2016, 07:10
Daniel
Daniel_Khazaei will become famous soon enough
Originally Posted by metmet View Post
God bless you man.
After you are done with your blocking: splits, edge bunching, etc...
Check your mesh by enabling the pre-mesh! if it's OK then save the blocking and disable pre-mesh! you can enable mesh to have your unstructured mesh presented.
go to file> Mesh > load from blocking and merge them! now both meshes are loaded as unstructured mesh and you can make them conformal at the interface!
metmet likes this.
Daniel_Khazaei is offline   Reply With Quote
Old   July 26, 2016, 05:33
ma.
M F
ma. is on a distinguished road
Thank you very much for the step-by-step-tutorial.
My problem is, that I'm not able to create mesh only for the inner (unstructured) part. I created 4 points around my inner geometry and connected them with curves. Then I set the material point inside this box. But how can I make sure, that only this box gets meshed with the unstructured mesh? I see in your picture under step 4, that you didn't delete the outer part.
ma. is offline   Reply With Quote
Old   July 26, 2016, 14:42
Daniel
No there is no need to delete the outer part, as you can see you should have an interface between these two regions! (surface)
Old   July 26, 2016, 14:44
ma.
M F
Thanks for your reply. But how can I do it without deleting? Is there anywhere an option where I can select the bodys I want to get meshed?
Old   July 26, 2016, 14:53
Daniel
creating a material point inside the inner part is enough! It should not mesh the outer box...
one more thing, try to split the domain in design modeler then import to ICEM CFD
Old   July 26, 2016, 14:58
ma.
M F
I will try that tomorrow when I have a PC with ICEM installed. Thank you!
Old   July 27, 2016, 13:57
ma.
M F
The meshing of the two different domains worked perfectly.
EDIT: The rest worked, too. I think the problem was because the size-difference between outer and inner mesh-elements was to big.
(Then I tried to merge the two meshes. When I used "File=>Mesh=>Load from Blocking" it didn't load the mesh of the inner domain. So I used "File=>Mesh=>Open Mesh..." and loaded the file with the meshed inner domain where the outer domain was not meshed. Then I pressed merge and saw both meshes in the way I wanted it.
After that I wanted to do the last step and did "Mesh=>Merge Nodes=>Merge Meshes" and activated my Interface (which I created at the beginning) in "Merge Surface Mesh Part" and confirmed. But I got an error which you can see in the picture and ICEM crashed.
Do you have any idea why this could happen? Maybe because of the "Open Mesh..." instead of "Load from Blocking"?
Thanks in advance!)
Far, metmet and Daniel_Khazaei like this.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[mesh manipulation] Combining multiple mesh blocks ingojahn OpenFOAM Meshing & Mesh Conversion 1 August 18, 2014 03:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
