[ICEM] unable to make a proper mesh for an impeller passage using a blocking strategy
Like Tree1Likes
  • 1 Post By JohnnyB
Old   May 30, 2014, 14:42
Default unable to make a proper mesh for an impeller passage using a blocking strategy
tmeysam92
tmeysam92 is on a distinguished road
Hi All,
i meshed an impeller passage in icem cfd. my blocking is not good. could you please help me?
i uploaded the icem cfd file in below link.
https://dl-web.dropbox.com/get/icem%...1LhbOsrAw&dl=1
tmeysam92 is offline   Reply With Quote
Old   May 31, 2014, 02:27
Default mesh pic
tmeysam92
any idea?
i attached the picture of geometry and my mesh.
please help me.
Old   June 2, 2014, 05:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
do you have access to turbogrid ?
Far is offline   Reply With Quote
Old   June 3, 2014, 08:33
tmeysam92
Hi Far,
No i could not access to turbo grid. as i told you in linkdin, i have to mesh with icem cfd, after meshing this impeller i should mesh volute.
can you please tell me, how can find a cell in icem cfd by it's number ? i mean when i export the mesh to fluent, it gives me error(no face with given nodes. thread 6, cell 74472). how can find this cell in icme cfd by this number(thread 6, cell 74472)?
Old   June 3, 2014, 08:34
tmeysam92
Hi Far,
Old   June 3, 2014, 11:18
Ion
JohnnyB is on a distinguished road
hello,
If you want I can help you to generate the mesh for the case, rotor+volute in icem cfd with blocking method...if you can send me the geometry in .stp or iges tomorrow i will send you the mesh...(my email address is ion.malael@comoti.ro)
JohnnyB is offline   Reply With Quote
Old   July 11, 2016, 08:42
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Can I send the step files of my geometry to you too and record the steps you will make to make it by myself? I am new in ICEM. I have an impeller, volute and the inlet pipe.
Ahmed Saeed Mansour is offline   Reply With Quote
Old   July 11, 2016, 09:04
Ion
You can send me the geometry but this can take some time, if you want to use only ICEM CFD...more easy is to use the meshing from Workbench..
Old   July 11, 2016, 09:09
Have a nice time!
Thank you very much for your reply. Actually I need some particular sizes may be lower than 1 mm around the blades and the critical zones and the skewness should be lower than 0.79. So, I can send the step files to you and please generate the hexa mesh and if you can record a video i will help me in the future. I use sliding mesh and I have to define the inlet, outlet, rotating zone, fixed zone and the interface. Thanks
Old   July 11, 2016, 09:17
Ion
if you want this mesh i can use turbogrid for rotor part...you will have a very good mesh with hexa for a single blade and multiply in ICEM CFD for all blades..and for volute i will use Workbench meshing with inflation on the walls
Old   July 11, 2016, 09:21
Have a nice time!
Okay, but please record your steps in a video. And at the end of the meshing I have to import the assembly of the pump (inlet pipe, impeller, and volute) to FLUENT. Thanks
Old   July 11, 2016, 10:52
Have a nice time!
I have sent an e-mail to sir.
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
