July 23, 2016, 04:43 |
face is attacted to more than 2 cells
Ron
Rep Power: 9 |
hello, i am a freshman of the cfd forums. and i have a problem when i output mesh as following statement.
the log: warning: mesh has uncovered faces. ansys fluent need a complete boundary{shells in 3D} or it will give a variety of errors and not read in the mesh. error:face(near node 135954) is attacted more than 2cells.[and there are hundreds of these errors.]error in computing cell connectivity. child process exited abnormally. i have searched the published threads, however, i still don't know how to solve the problem. if you know the reason, please tell me, thanks a lot. |
July 23, 2016, 10:17 |
Daniel
Rep Power: 21 |
It's probably an association issue with the boundary edges!
if it's a 2D problem then you need to associate every curve to its corresponding edge! |
July 26, 2016, 05:27 |
Ron
Rep Power: 9 |
ok. thank you very much, daniel. i have found out that penetrating elements may cause uncouvered face. so, it is better to check mesh to find whether the vertices(of your blocking) is in correct position, because i use the transform mesh!
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
