[Other] Difference between Mesh independance study and Mesh Sensitivity Study |
December 13, 2013, 04:53 |
Kunal
Rep Power: 14 |
Hello all,
Could you please explain me the difference between the two terminologies, 'Mesh Independence Study' and 'Mesh Sensitivity Study'. To me they seem similar. Can somebody explain this please? |
December 13, 2013, 05:45 |
Stuart
Rep Power: 25 |
I don't think there is any difference, much like saying what's the difference between a grid and a mesh or a cell and an element, it's just terminology. In lots of cases a mesh independent solution cannot be obtained because either the physics (models) or the available computational resources (very fine meshes required) prohibit a mesh independent solution being obtained. However, one can still, and should, assess the sensitivity of a solution due to the mesh resolution.
December 13, 2013, 06:00 |
Alex
Rep Power: 47 |
I find the terminology mesh independent quite misleading.
Looking close enough at the results, one will always find that the values change when changing the mesh size (provided a non-trivial case). |
December 13, 2013, 06:55 |
Rick
Rep Power: 26 |
Maybe one is related to mesh type (hexa, tetra, mixed) and the other to cell size.
Daniele |
September 1, 2016, 21:31 |
#5 | |
Sedat
Rep Power: 9 |
Hope this helps, Best |
[ICEM] Export mesh statistics for use in Richardson Extrapolation for grid sensitivity study | JuPa | ANSYS Meshing & Geometry | 13 | July 5, 2018 08:35 |
Mesh Independent Study | isuru | Main CFD Forum | 17 | March 26, 2013 11:35 |
[ANSYS Meshing] Any way around mesh study using mesh stats? | Torque_Converter | ANSYS Meshing & Geometry | 5 | June 4, 2012 10:07 |
Dynamic mesh in Fluent to study tire in contact with road surface | lihuang | FLUENT | 10 | March 8, 2011 10:21 |
Need for Mesh Independence Study | nickninevah | Main CFD Forum | 6 | October 15, 2010 17:25 |
