[ANSYS Meshing] Edge orientation in annular mesh
Like Tree1Likes
  • 1 Post By Kapi
Old   September 1, 2016, 10:01
Default Edge orientation in annular mesh
Vitor Braga
vbraga is on a distinguished road
Greetings,
I need to mesh a small annular gap between cylinders (Figure-domain), and I'm trying to get only Quads in the front and bottom surfaces, as you can see in Figure-Quads. However, as you can see in Figure-Skewness, as we follow the circumference, the skewness gradually increases until the quad breaks into a triangle. I would like to keep all elements in this suface as quads, with their edge gradually changing according to the position in the circumference. It doesn't seem like a difficult task to perform, however I've already tried a lot of different methods in ANSYS Meshing, such as Sweep (with only Quads), changing curvature angle etc. All to no avail. Does anybody know a way to achieve only quads in this surface using either Meshing or ICEM?
In short, I want a mesh with elements like presented in Figure-Quads, instead of what I'm getting in Figure-Skewness. Help please! xD
Thank you for any advices!
PS.: sorry if I'm repeating a question already answered in other threads, but I didn't find anything on the subject.
vbraga is offline   Reply With Quote
Old   September 4, 2016, 23:49
Kapi is on a distinguished road
have u tried using "sizing" function with "hard" behavior?
increase and decrease the size depending on your geometry size
vbraga likes this.
Kapi is offline   Reply With Quote
Old   September 6, 2016, 08:57
Vitor Braga
Thank you for you reply, Kapi. I`ve tried what you suggested but didn`t work. However, I managed to solve my problem switching both Transition and Smoothing to Fast and High, respectively, as I read in the User Guide.
Cheers.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
