[ANSYS Meshing] Suggestions needed for meshing axial flow pump with thin tip gap
Prev Previous Post   Next Post Next
Old   October 23, 2016, 21:35
Default Suggestions needed for meshing axial flow pump with thin tip gap
Jason
jason580315 is on a distinguished road
I don't have too much experience with meshing. I'm using ANSYS meshing. I want to simulate the flow in axial pump with 0.01 inch tip gap (the distance between stationary wall and rotational blades. I learned that I need to use inflation for boundary layer ( the stationary wall). For this thin gap, how to set up the inflation parameters appropriately to capture the fluid around the blade? Do I also need to use inflation for the rotational boundaries (the wall of blades and hub)? Which meshing software is easy to pick up for beginner? Thanks a lot!
jason580315 is offline   Reply With Quote
axial flow pump, inflation, thin gap
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 10:26
modelling of gap leakage flow in centrifugal pump melvin CFX 3 January 14, 2008 16:40
axial flow pump, inflow boundary tma CFX 3 September 26, 2002 15:28
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
