[ICEM] Problem with multizone method for Piston/Valve tutorial
Old   October 28, 2016, 06:18
Question Problem with multizone method for Piston/Valve tutorial
Quang Le Dang
SPH_CFD is on a distinguished road
Dear All,
I try meshing Piston/Valve Assembly tutorial using multizone method.
However, when I use 2D surface blocking, I cannot generate surface mesh of PORT near Cylinder and GROUP (STEM+VALVE+SEAT).
I realize that surface of PORT include 2 types (Faceted Surface and B-Spline Surface).
The part of B-Spline surface cannot be meshed with 2D surface blocking.
I also try to convert B-Spline surface to faceted surface but it is impossible.
Do you have any advice for me to solve this problem?
Thank you in advance.
SPH_CFD is offline   Reply With Quote
A problem in applying Non-Stationary relaxation method (GMRES) mb.pejvak Main CFD Forum 0 February 4, 2014 21:57
FSI Problem - Utilizing ALE method to map solutions natern OpenFOAM 1 November 7, 2011 17:00
Problem with the Fan tutorial widedMed OpenFOAM 3 March 29, 2011 04:35
finite difference method for navier-stokes problem dallybird Main CFD Forum 5 February 17, 2003 22:00
use of MAC method to solve sloshing problem. S.R.SAHI Main CFD Forum 1 April 15, 1999 22:28
