[ICEM] Problem with multizone method for Piston/Valve tutorial |
October 28, 2016, 06:18 |
Quang Le Dang
Dear All,
I try meshing Piston/Valve Assembly tutorial using multizone method. However, when I use 2D surface blocking, I cannot generate surface mesh of PORT near Cylinder and GROUP (STEM+VALVE+SEAT). I realize that surface of PORT include 2 types (Faceted Surface and B-Spline Surface). The part of B-Spline surface cannot be meshed with 2D surface blocking. I also try to convert B-Spline surface to faceted surface but it is impossible. Do you have any advice for me to solve this problem? Thank you in advance. |
A problem in applying Non-Stationary relaxation method (GMRES) | mb.pejvak | Main CFD Forum | 0 | February 4, 2014 21:57 |
FSI Problem - Utilizing ALE method to map solutions | natern | OpenFOAM | 1 | November 7, 2011 17:00 |
Problem with the Fan tutorial | widedMed | OpenFOAM | 3 | March 29, 2011 04:35 |
finite difference method for navier-stokes problem | dallybird | Main CFD Forum | 5 | February 17, 2003 22:00 |
use of MAC method to solve sloshing problem. | S.R.SAHI | Main CFD Forum | 1 | April 15, 1999 22:28 |
