[ANSYS Meshing] Two Separate Geometries (HVAC) |
November 3, 2016, 09:59 |
Scott kaufman
Hey learning to model for Radiation and convection HVAC currently.
Steps > Create .stp file in Catia > Create fluid domain in CFX: Design Modeler > Insert new geometry > Move geometry to middle > RMB Bodies, 'form new part' > CFX:Mesh > Problem: Meshing is not being applied to both bodies. Only fluid domain and the geometry inside is unmeshed. Where am i going wrong? I'm trying to mesh both bodies. Make the fluid domain the sky and the part of the atrium radiation. |
HVAC CFD Software? Best option? | birdman2447 | Main CFD Forum | 7 | May 6, 2023 07:59 |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
[ANSYS Meshing] Match control at interface between two separate geometries | davidrobinson50 | ANSYS Meshing & Geometry | 42 | July 19, 2018 05:51 |
HVAC Tool | tian | OpenFOAM Announcements from Other Sources | 9 | March 30, 2013 02:57 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 15:46 |
