November 5, 2016, 18:21 |
Edge's Node Growth Ratio
William
Rep Power: 9 |
I'm using a third party program to write a script to generate replay file with different meshing parameters. In some cases I don't have any preferred wall spacing and I don't want to have fixed number wall distance. Is there some mesh law where I don't need to define any spacing but still be able to use some growth ratio? I have this line where I want the cells to grow by 20% from beginning towards the end. But for this to work I must define the spacing also. For example, when using: Edge: 49 42 -1 Nodes: 100 Mesh Law: BiGeometric Spacing 1: 0 (Undefined) Ratio 1: 1.2 Spacing 2: 0 (Undefined) Ratio 2: 2 The result will give me a uniform distribution of the nodes. |
November 7, 2016, 05:00 |
Sebastian Engel
Rep Power: 20 |
Hello William,
you can define the spacing relatively. There is an extra checkbox to activate this feature. Then you should be able to define 0.2 spacing on one side. With regards, Sebastian |
November 8, 2016, 17:05 |
William
Rep Power: 9 |
Yes, there is this "Spacing Relative" check-box. It doesn't seem to make any changes unless I define a some spacing, which I preferably don't want in this case.
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[surface handling] SurfaceFeatureExtract Foam::error::printStack | donQi | OpenFOAM Meshing & Mesh Conversion | 1 | August 15, 2013 00:43 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
diesel spray combustion equivalence ratio | usker | Siemens | 12 | March 1, 2008 06:09 |
