[ANSYS Meshing] ICEM CFD- Two Blocks with non aligned grid lines
Old   November 28, 2016, 17:12
Default ICEM CFD- Two Blocks with non aligned grid lines
Eman. is on a distinguished road
I have a Geometry (here) and I want to use different mesh for the cylinder and the square block such that at their interface the grid lines of each block do not match with each other. (Later, when I am solving it I will interpolate between these non-matching grid lines). I've been trying to do so using blocking in ICEM CFD but it seems like there must be a smooth transition between each block and the grid lines must match. Is it possible to create this kind of mesh with two separate blocks with non-aligned gridlines at their interface?
Thanks
Eman. is offline   Reply With Quote
ansys, icem cfd, mesh, non conformal mesh
[TurboGrid] turbogrid to icem cfd then icem cfd to fluent tmeysam92 ANSYS Meshing & Geometry 0 May 7, 2014 06:25
[ICEM] Unstructured meshing of a grid fin in ICEM CFD ToORAGe ANSYS Meshing & Geometry 4 January 27, 2014 10:34
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 14:37
