December 30, 2016, 09:57 |
Regarding O Grid
Vish
Rep Power: 13 |
Hi All
I am newbie to ICEM and to CFD in general. I have started learning ICEM rcently on my own with online help. I understand that the USP of using ICEM is O Grid. But I have a fundamental question regarding the O Grid. I have a block which has many adjacent blocks around itself- it is not on the boundary. I want to create a O grid into it such that the O Grid touches the surfaces/ faces of that block but does NOT Pass though any of the faces to the adjacent blocks. How do I do that? I understand that by selecting faces , we will allow the block to pass through that surface/ face. This means that if we select only a face and no blokcs, the O Grid wil go through it to adjacenet block On the other hand, if I select only block and no faces, the O Grid will totally be contained inside the block but will not touch the face. I want both- I want the O Grid tp be contaided insdie the block, but the O Grid should end at the faces, not go beyond that. I appreciate the help Regard |
Fluent LES model: grid requirement? | dinhanh | FLUENT | 1 | November 11, 2015 12:15 |
How to make grid for LES simulation | dinhanh | Main CFD Forum | 3 | November 11, 2015 02:37 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Grid Quality and the Solution | Faraz | Main CFD Forum | 4 | January 10, 2000 18:18 |
