January 4, 2017, 08:09 |
Surface missing while meshing
Felix
I'm working on meshing a part with a rough surface. Usually you would want to smoothen the geometry but since it is important to keep the geometry as is, to know specifically how the fluid solid interaction is taken place, it has to stay that way. I could use the global mesh setting in ICEM but it doesn't provide the mesh quality that I want it to have. After blocking is initialized, I assosiate the edges and curves as well as the surfaces to the faces. Unfortunatly one small part of the mesh is always missing. It seems like it can't generate the mesh. However, it does it perfectly on the opposing site. In addition to that it is not a 3D mesh. Only a 2D mesh dispite me using the 3D blocking. I'm adding several pictures to illustrate the problem better. https://www.dropbox.com/s/1rq3bkeiks...ble01.png?dl=0 Thank you for your help in advance. Cheers. |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[DesignModeler] Sweeping or surface meshing in enclosure? | Edu-R | ANSYS Meshing & Geometry | 9 | January 23, 2013 13:41 |
Problem with segment surface and meshing | Silmaril | ANSYS Meshing & Geometry | 1 | October 13, 2011 16:42 |
Anisotropic surface meshing | fxzf | Main CFD Forum | 0 | March 7, 2011 05:21 |
Surface Repair for Meshing | Andy R | Main CFD Forum | 13 | May 3, 2008 14:33 |
