January 18, 2017, 15:49 |
Vertex Association Fix
John
I am new to ICEM, I went through a tutorial on 3D meshing a NACA 0015 wing. One of my associations was mistaken and the whole mesh is messed up. I am unable to undo the error because I have since saved and closed the file. Is there a way to fix this or will I need to start over? Please see pictures attached. Thanks, John |
January 19, 2017, 02:06 |
Stuart
Rep Power: 25 |
Can you not just disassociate that vertex? See ICEM CFD help/icm_help/iblock_dissoc.html
January 19, 2017, 02:18 |
#3 | |
Rep Power: 18 |
January 20, 2017, 18:21 |
John
Thank you very much, I did not see the remove association command
ill defined primitive entry 'boundary' | francisco.angel | OpenFOAM Pre-Processing | 16 | September 8, 2022 06:11 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
