February 8, 2017, 17:29 |
copy block
Rep Power: 12 |
hey
im trying to copy the block (bottom up way) but while copying some of the block get the same number as the original one and then when e.g. deleting one of the copied, the original is also deleted (as is numbered the same way). how to avoid the numbering issue? |
February 11, 2017, 13:04 |
Koray G.
Rep Power: 10 |
Maybe it works. After you copy blocks apply this step; Blocking > Check Blocks > Method: Run Check/Fix I have experienced same problem. In this way I solved the problem. I wish you good work. |
February 11, 2017, 17:54 |
N+
Rep Power: 12 |
hey
thanks for the response i also think the renumbering can help - will try it too |
[ICEM] copy block to many small cyliders in a grid | SPH_CFD | ANSYS Meshing & Geometry | 2 | November 28, 2016 16:11 |
[blockMesh] Inconsistent number of faces between block | CrisMoreira | OpenFOAM Meshing & Mesh Conversion | 10 | April 28, 2015 19:06 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
