[DesignModeler] How to generate geometry files |
February 15, 2017, 05:46 |
Hi everyone,
I'm new to the forum and I did several searches on Google before posting. I couldn't find a clear answer, though I guess I'm not the first with that problem. I have rahter complex 2d geometries to set up for Fluent studies. I'd like to generate points under Matlab or Octave (from x y coordinates for example) since it's far easier than manually entering my geometries in Modeller. I tried to export simple geometries from Modeller in the different available formats (parasolid, igs...), still I can't figure out these files structure by editing them with notepad++. Can someone tell me what format would be "easier" to deal with and where I can find explanations about file structure (header and geometry syntax)? Best Regards Greg |
ansys geometry import |
[ICEM] generate a curve or surface in the axi-symmetric geometry with ICEM | openfoammaofnepo | ANSYS Meshing & Geometry | 9 | June 11, 2016 00:42 |
[snappyHexMesh] How to generate geometry - multi region stl, obj | wersoe | OpenFOAM Meshing & Mesh Conversion | 0 | June 1, 2013 03:02 |
How to generate STL files for idealized geometries? | werder85 | Main CFD Forum | 0 | November 1, 2012 12:47 |
Ability to Generate a Grid with Steps in Shroud Geometry | jonny_b | Fidelity CFD | 0 | October 7, 2011 14:43 |
creating geometry using "Script files" in ICEMCFD | jaber | Main CFD Forum | 1 | November 11, 2007 09:28 |
