[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters)
Old   January 29, 2017, 10:43
Default 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters)
shubham jain
shubham jain is on a distinguished road
Hello
I am simulating boundary layer blowing for airfoil, and using a Hybrid mesh (structured block near airfoil, unstructured mesh for rest of the domain)
Structured mesh is working fine, but my unstructured mesh is very moody (sometimes it works, sometimes not)
1. It is highly sensitive to number of nodes, cell size of structured domain. It messes everything, when I change either the first cell height of structured mesh, or number of nodes after a certain limit. Unstructured mesh is generated everytime, but it is very bad.
Pictures attached are correct mesh and bad mesh (zoomed out). Here I changed the first wall size from 3e-4 to 2e-4, and it got screwed .
2. Also I am not able to control none of the parameters of unstructured mesh (growth rate, max size, min size). First cell size of unstructured mesh is matched to last cell size of structured, but after that I cannot control it. I tried to change the values in "Part mesh setup", "surface mesh setup", "global mesh setup", but nothing works .
Any advices would be helpful
PS: I created structured block within an interface curve. Then I create a patch dependent unstructured mesh on the surface outside the interface curve.
Thank you
Shubham
shubham jain is offline   Reply With Quote
Old   April 10, 2017, 05:03
N B Khan
bestniaz is on a distinguished road
Originally Posted by shubham jain View Post
Hello
Thank you
Shubham
Hi Shubham,
I am also doing the same type of problem,,, I able to do it with workbench mesher ( fluent)...
Email me on n_bkhan@yahoo.com to discuss it in detail.
Regards
Niaz
bestniaz is offline   Reply With Quote
Volume mesh for Cyclone separator Rajan Pointwise & Gridgen 17 May 4, 2014 05:38
Difference between structured & unstructured mesh Andrew Main CFD Forum 2 February 20, 2003 08:40
Structured Grid Definition craig shores Main CFD Forum 3 March 21, 2001 14:48
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
