[ICEM] Question about backward compatibility
Old   April 18, 2017, 09:47
Post Question about backward compatibility
Mandeep Shetty
granzer is on a distinguished road
Is ICEM 17 backward compatible with ICEM 14.5? I want to open the project files made in ICEM 14.5 in ICEM 17 to run the mesh quality check.
granzer is offline   Reply With Quote
Old   June 23, 2017, 08:14
Javi
FJSJ is on a distinguished road
Hi Granzer,
As fas as I know, I think you don't have problems with forward compatibility. However, backward one, I think...is restricted to just the current release and the two previous..
For geometry, there is no problem becasue you can save your tetin file as other previous releases.. but for blocking... the only thing I know is the legacy ANSYS ICEM CFD 4.0 format... and ANSYS ICEM CFD 5.0 is currently working from ANSYS 11...
Hope this helps...
FJSJ is offline   Reply With Quote
Old   June 24, 2017, 02:42
Mandeep Shetty
Hello FJSJ,
Thank you for the reply.Yes, the project file did work in ICEM 17.I had compatibility problem when working with fluent. Glad that didn't happen with ICEM.
backward compatibility, icem 14.5, icem 17
Guide: How to ask a question on the forums jola Site Help, Feedback & Discussions 0 July 29, 2016 18:52
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
