[ANSYS Meshing] refining the mesh in the depth |
July 15, 2017, 07:34 |
dilaw meda
Rep Power: 8 |
hi , this is a cross section of the domain. i wanted to do a refinement in ansys mesher , but it only refine the exterior surface of the nozzles (like it is showing in the photo). i want to refine in the depth of the domain at the jet flow region where there is serious turbulence . any help please
July 15, 2017, 08:38 |
Korupolu.ramesh
Rep Power: 8 |
July 15, 2017, 10:32 |
dilaw meda
Rep Power: 8 |
July 15, 2017, 13:04 |
Stuart
Rep Power: 25 |
Have you tried putting a face sizing on each nozzle with a smaller element size than that assigned to the body? Or you could make a body or bodies in DesignModeler (or similar) and use them as a Body of Influence in the Body Sizing around each or all of the nozzles depending on the shape of them. Other option is to set in the Advanced Size Function to Curvature and/or Proximity (depending on what you like) at the global mesh level to refine the mesh at the nozzles. See how those 3 choices work out for you and also review the Meshing Training Material on the ANSYS Customer Portal as this is covered in detail their.
July 15, 2017, 13:12 |
#5 | |
dilaw meda
Rep Power: 8 |
Sent from my F1f using CFD Online Forum mobile app |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ANSYS Meshing] guidance about refining hex mesh? | hamidciv | ANSYS Meshing & Geometry | 15 | July 27, 2015 02:28 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
