[ICEM] Script command for "select all"?
Old   August 30, 2012, 13:56
Default Script command for "select all"?
François Grégoire
macfly is on a distinguished road
Dear modelers,
Is there a script command in order to select all entities of a given family? e.g., select all points, select all lines, select all surfaces, etc.
Example : I would like to select all visible curves in order to create a new part containing all the curves.
I sweep tons of 2D sufaces in order to create my 3D geometry, therefore I lose track of the vertex names, curves names, surfaces names, etc. After my geometry is done, I want to clean my model and automatically create separate parts containing all vertex, all curves, all surfaces, etc.
Regards,
François
macfly is offline   Reply With Quote
Old   September 2, 2012, 11:37
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Hi Françoi,
Try the following:
ic_geo_set_family curve partname all
You can change "curve" to "surface" if you want to put all the surfaces in a part. Also replace "partname" with the name of the part you want to move things to.
Good Luck
Stu
stuart23 is offline   Reply With Quote
Old   September 2, 2012, 20:29
François Grégoire
Thanks Stuart, in Icem CFD 14.0 the following commands create 3 separate parts with points, curves and surfaces:
ic_geo_set_family point POINTS all rename
ic_geo_set_family curve CURVES all rename
ic_geo_set_family surface SURFACES all rename
Regards
François
Old   September 2, 2012, 20:56
Stuart Buckingham
François, you are correct. I had forgotten to add "rename" to the end
Old   August 1, 2017, 07:41
Default Select all
Sunil
sunilkonatham is on a distinguished road
Hello all,
In the similar way explained, can you please tell me how can I "select all" to scale them by 5 times for example?
sunilkonatham is offline   Reply With Quote
Old   August 1, 2017, 08:06
Sebastian Engel
bluebase will become famous soon enough
Hi Sunil,
a function to select all entites of a defined type is:
ic_geo_get_objects entitytype
replace "entitytype" by curve, point, or surface to get a list of all entites of that type.
with regards,
Sebastian
bluebase is offline   Reply With Quote
[ICEM] Script: problems with face names Maweil ANSYS Meshing & Geometry 3 April 16, 2019 09:10
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
how I can write the file script to submite via HPC cluster at my UNI happy CFX 2 October 17, 2011 02:18
CFX mesh script error Malik77 CFX 0 June 24, 2011 07:42
Perl script for intialisation pratik mehta CFX 2 September 10, 2008 03:09
