[ANSYS Meshing] how to deal with unavoidable high skew cells
Old   September 29, 2017, 03:49
Thumbs up how to deal with unavoidable high skew cells
vipul ram k p
vipulramk is on a distinguished road
I have 3D conjugate heat transfer problem with around 5 crore cells, I am having a condition where few cells are having a skewness greater than 0.98 (~4000 cells), I am in a situation where I cant improve the mesh since I have "RAM" restrictions. I am presently using RNG K-epsilon, enhanced wall function turbulence model. I have observed that in these cells my turbulence model is unable to converge and producing misleading velocity results.
but my energy equation is has reached stability with an error 1e-6 very early during the simulation (around 50 iterations) can someone shed some light on how to tackle this problem?
Also, I am using ANSYS Fluent to solve and the geometry is an Electric motor and is quite complex.
Thank you.
vipulramk is offline   Reply With Quote
Old   October 2, 2017, 12:22
plucas's Avatar
Anonymous
plucas is on a distinguished road
I would look into maybe a cloud solving solution where you can get a better mesh like Nimbix
plucas is offline   Reply With Quote
Old   October 6, 2017, 05:40
Paritosh Vasava
vasava will become famous soon enough
I recommend the following:
  1. Convert mesh to polyhedral. This should significantly reduce number of cells.
  2. Use fluent commands to remove mesh anomalies.
  3. Make a simpler and coarse mesh. See if everything works ok. If so then make a finer and complicated mesh.
vasava is offline   Reply With Quote
ansys fluent, ansys mesher, ansys workbench
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 07:09
use of high aspect ratio cells near walls Usman FLUENT 0 January 23, 2008 07:16
wedge cells pridicting high T-KE why? shan Siemens 0 September 21, 2006 14:12
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
