[DesignModeler] No airflow on the side of a Wing |
September 30, 2017, 11:47 |
Thomas
Rep Power: 8 |
Hello everyone,
I want to simulate a rear wing of a car. To reduce the mesh, I simulate only 10% of the wing broadness. The problem I have: I don't want the air to flow on the side of the wing, the air should just flow about and below the wing. How can I get this boundary conditions? The enclosure only takes values of >0... Is it possible with symmetry settings? I haven't found any solution. PS: 2D isn't possible because of irregularities on the wing. thanks in advance |
October 3, 2017, 13:02 |
Gwenael H.
Rep Power: 20 |
Hi Thomas,
Well you could still use the enclosure tool with an arbitrary value for the out of plane domain you don't want (>0). Then create 2 planes at both extremities of your wing geometry and slice the enclosure. You can then suppress those parts and you'll end up with what you're looking for. Have fun |
bounadry condition, symmetry |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
