[TurboGrid] TurboGrid Defining TE and LE in File |
November 3, 2017, 02:52 |
Daniel
Rep Power: 9 |
i have a problem with importing coordinates of a blade into TG. The Blade has 5 Profiles. I defined the Profiles like usaual with: # Profile 1 at 0.0% (hub) .... But i get the error: Trim oepration failed to produce any surfaces... This Error was discussed before here. The solution was, to define TE and LE in the file. And I tried to do this like explained. But it doesn't work. So I wanted to check, if I defined te TE and LE right. In the picture you can see the profile at 75% Span. On the others, I marked whicht points I defined in the .txt-File as TE (TE2) and LE (LE2). Is this right ? Or do I need to set the defintions at other points ? Thank you for your help!! |
November 3, 2017, 05:25 |
Daniel
Rep Power: 9 |
Fixed it by myself.
Don't know why, but the 100% Span Points weren't in Order. Now it works |
