[ANSYS Meshing] & SpaceClaim Baflles shared topology
Old   November 20, 2017, 12:29
Default & SpaceClaim Baflles shared topology
LUCJAN POZORSKI
jacekPOZOR is on a distinguished road
hello
I want to share topology between surface and volume, i wonder how to share topology baffles witch is completly within volume,
Can someone suggest me how to set up this problem in SpaceClaim 18.2 and ansysMeshing 18.2?
I wonder how i have to construct a modell tree.
Should i have to put surfaces and volumes into separate part and merge it?
I do this like below:
ASSEMBLY OF DOMAIN WATER: (SHARE)
WATER 1 (SHARE)
SUB-ASSEMBLY DOMAIN WATER AND BAFFLES: (SHARE)
PART 1 - Volume (SHARE)
PART 2 - Baffles (MERGE)
and it takes no effect- Fluent cant see baffles as wall "0" thcikenss.
Manual says that i have to use MEREGE operation, but i wonder what with what excatly i have to merge?
I don want to merge all water domain, water blocks have to share with each other.
jacekPOZOR is offline   Reply With Quote
Old   November 23, 2017, 08:32
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Lucjan,
It’s a bit difficult to figure out the geometry you’re trying to model, as we say a picture is worth a thousand words
As a general guideline, in SC if you have several entities you can regroup them in a component and decide which option of Share topology you want (i.e. None / Group / Share / Merge). Moreover in SC under the workbench tab > sharing , you have access to different tools to imprint areas / faces to across different bodies. This should solve your problem.
Have fun
Gweher is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
