[TurboGrid] Move Passage Boundary
Like Tree1Likes
  • 1 Post By AtoHM
Old   December 15, 2017, 06:35
Default Move Passage Boundary
Daniel
zacko is on a distinguished road
i have a question about meshing a blade in Turbogrid.
In the two pictures you can see two different blades. These were meshed in Turbogrid. My problem is, that the passage boundarys are not at the same position. In one case the blade is centred and in the other the blade shifts to the top. Is there any option in TG that I can adjust the centred blade with the same angle ?
In Post I wanted to compute expressions in circumferential direction (theta). But with this shift they aren't that good to compare.
Thank you very much!
zacko is offline   Reply With Quote
Old   December 15, 2017, 09:13
M
AtoHM is on a distinguished road
Yes,
In Geometry > BladeSet Options and way down there is an option called "Bias of Blade towards High-Periodic". Its normally set to 0.5, which means centered between the periodic boundaries, see what fits your case best.
zacko likes this.
AtoHM is offline   Reply With Quote
Old   December 15, 2017, 09:23
Daniel
Originally Posted by AtoHM View Post
Yes,
Oh perfect, Thank you very much
Old   December 18, 2017, 04:30
Daniel
I have a new problem. When I change the value, only the outline changes. The topology and the mesh stay centered. I have tried many things, reread every tab and even imported the curves new, but it won't update the topology to higher periodics.
Is there any trick ?
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Radiation interface hinca CFX 15 January 26, 2014 17:11
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
