[DesignModeler] Circle at spesific location, probably a easy question. |
December 20, 2017, 13:47 |
Mathia
Rep Power: 8 |
Hello, very new to Ansys. I would like to create a circle at the exact location (x,y)=(-2.1,3.05) in DesignModeler (sketch). How can this be done? Everything seems to be constraied. I would also like to create a rectangle that has corners at spesific points. Tried to google this for a couple hours now lol, without finding an answer
December 22, 2017, 04:40 |
Gwenael H.
Rep Power: 20 |
Hi Mathia,
You have several possibilities, but maybe the easiest one for you is to create your circle in the XY plane and then use a move operation where you specify your coordinates. Otherwise you can create a construction point > manual inputs and then use a plane through point to start sketching at that point. Have fun |
Femlab easy question? | Sab | COMSOL | 1 | June 8, 2006 05:24 |
Quick and easy QUESTION | Freeman | Main CFD Forum | 12 | December 13, 2005 15:00 |
Easy question | Confused | Main CFD Forum | 4 | May 22, 2004 02:14 |
Easy Question | chacha | Main CFD Forum | 1 | February 27, 2004 03:07 |
an easy question about gambit | brian | FLUENT | 3 | December 2, 2002 23:58 |
