[ANSYS Meshing] Cutcell left handed faces
Old   January 4, 2018, 06:55
Default Cutcell left handed faces
paul.grasboeck
paul.grasboeck is on a distinguished road
Dear all!
I am currently working on the simulation of the external aerodynamics of a car with a little bit of underhood regions and I am using the CutCell method in Fluent Meshing mode (18.1).
My problem is that the mesh check fails due to some left handed faces even without morphed prism layers. When I add prism layer more left handed faces occur.
For testing purpose I even neglected the underhood part to simplify the geometry. I also visualized the left handed faces and removed the areas in the model. After remeshing left handed faces appear somewhere else in the mesh.
The CAD input files are .stl.
I wrap them to get a surface mesh.
I check and modify the surface mesh to get 0 free, multi and duplicate faces and a maximum skewness of <0.7.
I really worked through all information and tutorials I could get about CutCell meshing.
Unfortunately I couldn’t find any information about left handed faces with CutCell in the Ansys Manual, the internet and this forum.
Commands like mesh/repair-face-handedness in Fluent Meshing mode and repair in Fluent Solution mode don’t seem to work.
Is there anybody having the same problems and solved them?
Is there maybe a vital check I didn’t do with the surface mesh?
Are there commands to prevent the formation of left handed faces prior to meshing or post meshing?
Generally I want (have) to stick with the possibilities of Ansys 18.1.
Furthermore I also want to stick with the CutCell method due to turnaround time and mesh size.
Thanks in advance!
BR
Paul
paul.grasboeck is offline   Reply With Quote
Old   January 4, 2018, 13:28
Evan
evevev is on a distinguished road
Sorry I can't help but I wanted to comment so I can follow this thread in case someone has a solution...I'm also having an issue with checking the cutcell mesh in fluent (although mine says that there is an element with only faces)
evevev is offline   Reply With Quote
cut cell, cutcell, left handed
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
