January 25, 2018, 04:49 |
Influence of Cu pipe on LN2 simulation
Anshab
Rep Power: 8 |
Hello All,
I am new here and I would like to clarify two doubts from you. (1) I would like to analyze the influence of the Cu pipe on LN2 simulation. I am using Ansys fluent (workbench) 18.2 and it has a lot of changes from previous versions. So I couldn't model the geometry because when I am trying to use fill option for creating a separate body inside the Cu pipe for LN2 flow, it has merged with outer body and forms the single solid body. Could you help to do the same? (2)Also, I wish to get some valuable comments from you for achieving better results for this task. Here I am mainly focusing different shapes of Cu pipes (Stright, 90-degree bend, 180-degree bend...). Looking forward to your reply and Thank you in advance |
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam | wuyangzhen | OpenFOAM | 10 | December 12, 2017 00:19 |
FLOEFD API for heat pipe simulation | debuger | FloEFD, FloWorks & FloTHERM | 2 | August 16, 2017 09:25 |
Fluent/icepak UDF for heat pipe simulation | debuger | Fluent UDF and Scheme Programming | 0 | July 19, 2017 12:05 |
3D simulation of buried pipe in Fluent | amir_051 | FLUENT | 1 | October 23, 2015 18:03 |
FDTD Simulation of flow through tapered pipe | Jim | Main CFD Forum | 3 | December 25, 2006 10:56 |
