[BladeModeler] BladeGen/ Turbogrid Tip clearance |
January 17, 2018, 11:51 |
Prakhar
Rep Power: 12 |
I am working on a case to estimate tip clearance effect in a radial turbine. I have already modeled my blade on bladegen and meshed the same in turbogrid with an acceptable mesh quality. However, I need to modify the shroud tip clearance to have multiple cases. I have tried doing it in turbogrid by using variable nominal distance at the leading edge and trailing edge. However, this results in trimming of the blade from leading edge and trailing edge. Is there a way by which I can keep my blade dimensions and offset the shroud to achieve different clearance magnitudes? Any help would be appreciated. Thanks in advance for your suggestions and help. Regards Prakhar |
bladegen, tip clearance, turbine blade geometry, turbogrid |
BladeGen/ Turbogrid Tip clearance | Prak_32 | Main CFD Forum | 1 | January 22, 2018 15:29 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
non-constant clearance for BladeGen and TurboGrid? | yuhai | CFX | 0 | October 31, 2015 05:54 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
