[BladeModeler] BladeGen/ Turbogrid Tip clearance
Old   January 17, 2018, 11:51
Default BladeGen/ Turbogrid Tip clearance
Prakhar
Prak_32 is on a distinguished road
I am working on a case to estimate tip clearance effect in a radial turbine.
I have already modeled my blade on bladegen and meshed the same in turbogrid with an acceptable mesh quality.
However, I need to modify the shroud tip clearance to have multiple cases. I have tried doing it in turbogrid by using variable nominal distance at the leading edge and trailing edge. However, this results in trimming of the blade from leading edge and trailing edge. Is there a way by which I can keep my blade dimensions and offset the shroud to achieve different clearance magnitudes?
Any help would be appreciated. Thanks in advance for your suggestions and help.
Regards
Prakhar
Prak_32 is offline   Reply With Quote
Old   February 4, 2018, 09:31
Far
Sijal
No. It is not possible. you can modify your shroud profile each time.
bladegen, tip clearance, turbine blade geometry, turbogrid
BladeGen/ Turbogrid Tip clearance Prak_32 Main CFD Forum 1 January 22, 2018 15:29
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
non-constant clearance for BladeGen and TurboGrid? yuhai CFX 0 October 31, 2015 05:54
Tip Clearance Liam CFX 3 September 7, 2005 05:30
Tip Clearance Drona CFX 0 October 17, 2002 05:25
