[DesignModeler] UGRENT HELP|| Boolean Operation Manifold Error on a file imported from solidworks
Old   February 15, 2018, 17:38
Exclamation UGRENT HELP|| Boolean Operation Manifold Error on a file imported from solidworks
Payar Radfar
PayarRadfar is on a distinguished road
Hi Guys,
I have a geometry, let's say its a pipe with a venturi after. My study is on the flow and see what speed ratio i can get with the venturi, keeping in mind that i have to have a really big domain and study the flow over and inside the "pipe".
I have designed the model in SolidWorks then I tried importing it to Ansys Design Modeler. Once I draw a bigger box and try to use boolean to subtract, I get the mani-fold error.
I have also read other threads on this issue such as; surface and body issues, edge to face issue. However, I cannot find the problem. I tried drawing a simple model as one part using revolve option (thickness of 10mm) and different sketches. Once it was imported, Design Modeler read as 3 parts and I can apply boolean successfully to 2 parts but there is always an error with one of the parts.
Then I tried the actual model with more than 500 parts as assembly it gave the same error. I also tried different file formats.
Could you please advise where I am possibly going wrong?
Thank you
Payar
PayarRadfar is offline   Reply With Quote
designmodeler, error, import, manifold, solidworks
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
