June 13, 2018, 11:10 |
Problems on airfoil tail mesh
Marco
Hi,I'm Marco and this is my first question on this forum.
I have done a mesh for a NACA0012 airfoil with 11% solidity on ICEM. Then I've repeated the same passages for a NACA0012 airfoil with 6% solidity (smaller chord). But in this case I have some problems with the mesh near the airfoil tail. I have done an arc to close the airfoil profile, then I have divided it in two parts and put 5 nodes on each one. I also have tried different types of junction (not only an arc) for the tail but the differences are minimal. I upload the two images to compare these two cases. Could anyone help me correct the second mesh? Thank you |
June 14, 2018, 04:30 |
Sebastian Engel
Rep Power: 20 |
Hi Marco,
can you try to put triangulation and topology tolerance to a much smaller value than your arc's radius, and try again? You could also play with the distribution of nodes over the arc in order to get smaller prims at the far end. If that's not helping, have a look on page 59 of "Simon's Tips&Tricks" guide which can be found in the sticky post of this subforum. Best regards, Sebastian |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
