June 27, 2018, 20:51 |
Mesh Pump
MGE_CFD
Rep Power: 7 |
Dear,
I'm doing a centrifugal pump simulation, I have a rotating (rotor) domain and a stationary (diffuser), but I'm not sure of the mesh of the interface region. I'm using Stage in setup, and the two domains are not in a single body in design modeler, for the reason I'm out of control on the node of each interface. How do I check if the interface region has no influence on my result? Thank you all. |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
A 3D sliding mesh in a centrifugal pump Fluent | Ahmed Saeed Mansour | FLUENT | 0 | September 17, 2016 13:18 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
